Home > Technical (L322) > Front lower arm bolt…
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Do any of you know why there are 2 different bolts KYG000042 & KYG000043 that do the same job?
The threads are a different length but wonder if it doesn’t matter which one is used? Is it as simple as one is factory and the other aftermarket?!
I have a 2009 3.6 TDV8 that has a knocking noise, spotted the front lower arm subframe bolt won’t tighten fully so suspect that is the issue.
Also is there any correct factory torque setting for these bolts aside from ‘tight’?
Any advice welcome…
Post #647342 4th Nov 2022 7:18pm
Merchy
If the bush is still in good condition, then it could be that the nut is tightening up as there is not enough thread, plus it could be a manufacturing defect with too short a thread ( not unknown )
Try removing the bolt. and measuring the distance across the bush etc and length of thread.
Note the OEM version shows a set screw ( Completely threaded and the other a standard bolt )
As for torque settings, these should be in the 'Wiki' section somewhere.
PS - When carrying out final tightening, this should be dome with the car on the ground, not jacked up.
Post #647359 4th Nov 2022 9:35pm
KitTheRam
Thanks for the advice. Will have a look for the wiki section, is that a search thing or a specific section of the site? (I’m quite new as you can tell!)
Post #647360 4th Nov 2022 9:39pm
dingg1
https://workshop-manuals.com/landrover/l32...uspension/
Post #647364 4th Nov 2022 10:08pm
mjdronfield
The Wiki is top right, under the fullfatrr banner…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #647366 4th Nov 2022 10:16pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #647367 4th Nov 2022 10:19pm
KitTheRam
Brilliant thanks.
On a different but relevant note - I need to buy a not too expensive torque wrench, any suggestions welcome!
Post #647369 4th Nov 2022 10:28pm
Phoenix
Not too expensive = inaccurate = might as well not bother.
Norbar have a good reputation in the mid-range stuff, i think Halfords sell them as own brand.
ETA - don't use a torque wrench for doing angular tightening, it can cause loss of accuracy unless it's designed for it, rather torque to setting then use a breaker bar for the angular tightening.
Post #647372 4th Nov 2022 10:44pm
KitTheRam
Noted.
Can’t see the one you mentioned but this seems to have got good reviews. Not a ‘named brand’ I know.
https://www.halfords.com/tools/hand-tools/...html?_gl=1*1g0u0ze*_up*MQ..*_ga*MTIzMzI4MTQxMS4xNjY3NTk4ODE2*_ga_VK44BRER97*MTY2NzU5ODgxNi4xLjEuMTY2NzU5ODgxNi4wLjAuMA..
Post #647373 4th Nov 2022 10:47pm
dhallworth
The different part numbers are due to difference chassis numbers according to the LR online catalogue.
Post #647375 4th Nov 2022 11:05pm
KitTheRam
Thanks. I guess they do the same thing so will go for the one with the longer thread.
In fact the longer thread goes with my vin, 9A…..
Post #647378 4th Nov 2022 11:20pm
Phoenix
This is the Norbar one - it's got a NSN which is always a good sign...
https://www.norbar.com/products/view/produ...5/id/22350
Looks exactly the same as the Halfords one to me.
Post #647380 4th Nov 2022 11:29pm
KitTheRam
Thanks. Found it for a £100. Will get it.
https://ffx.co.uk/product/Get/Norbar-Nor13...e-60-300Nm
Post #647381 4th Nov 2022 11:39pm
landy95
Halfords advanced version has a lifetime warranty. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #647453 5th Nov 2022 11:36pm
