![]() | Home > Technical (L322) > What is this part? |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 276 ![]() ![]() ![]() |
Hi Everyone,
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Damned rodents |
Yep, I'll almost certainly end up doing the RTV patch. But, I'd still like to know what it is. If it's not too expensive and not too difficult to replace I may replace it.
Could this be the part? It's hard to tell from the parts images.
The front left corner of your picture is another wiring loom the mice seem to love! Had several cars in with spurious faults due to rodent damage!!! |
RTV won't adhere? Never even considered the possibility. I'll swing by my local car parts store to buy some of the tire patch you suggested. Thanks, Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
The black plastic one or the brown ground wire? The ground wire has already been chewed up a bit too. I'm going to replace that since it's an easy replacement. Thanks, Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
The Black plastic one… if you have the time? I did a small write up on just this issue and put some pictures up where some customers cars were chewed and what the wiring was for (if I remember correctly?) 👍 |
