![]() | Home > In Car Electronics (L405) > 360 Degree camera blurry? |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 637 ![]() ![]() ![]() |
No...but obviously earlier tech on the 2017. Mike - MPx
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 ![]() ![]() ![]() |
Hi all, this is the issue I am having. As you can see the forward camera image is clear but the 360 view of it is blurred.
mgibson Member Since: 24 Nov 2023 Location: Oxford Posts: 6 ![]() ![]() ![]() |
Just been to dealer as rear camera failed on my 2018 L405 with 360 cameras , they rejected claim under Land Rover warranty as water ingress caused the fault . As a courtesy they washed the cars so now three cameras not working and fogged up . Surely dealers should tell valeters to keep jet washers away from door handles and cameras . Hope that they dry out and I can seal the lenses with Vaseline when they start working again . Dealer is looking at replacing the failed rear camera though so fair . Don’t jet washers any Landrover ! |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 199 ![]() ![]() ![]() |
it's not blurry. It is not calibrated, and at top view you have whole wide view from camera.
noone Member Since: 05 Apr 2025 Location: Florida Posts: 95 ![]() ![]() |
I have this exact same issue. Did you ever resolve this? Surely there has to be a way outside the dealer to fix this. 2023 L460 Range Rover SE P400
