Home > Technical (L405) > Driver door won’t latch
kgeddes
Opened car this evening, jumped in and door won’t latch. I’ve tried wd40 and manually working the mechanism but no joy. Any ideas? Thanks
Post #648565 19th Nov 2022 7:55pm
Dolphinboy
It may be frozen inside. My earlier L322 used to do this. Warmed it up and it worked. Try silicon spray instead of WD40.
Post #648578 19th Nov 2022 11:46pm
Spray some de-icer in there? Thumbs Up
Post #648583 20th Nov 2022 12:45am
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
I had this last week. Door latch needed replacing. I've had it done on 3 doors now. A common fault. They also get stuck shut.
Post #648589 20th Nov 2022 8:05am
kgeddes
Many thanks for replies. Called AA (local garage attended), mechanic gave side of door mechanism three taps with his screw driver/hammer and it freed itself (something to do with a spring). He then drowned the mechanism in lubricant. All fine now but he says it will have to be replaced and job will have to be done by dealer as it has to be programmed.
cupples8267 - did you have to have the work done by dealer and can you give me an idea of the cost please?
Thanks again…
Post #648595 20th Nov 2022 9:36am
cupples8267
I got mine done by the dealer under warranty so unsure of cost. Its a common issue for the door latches to go. Mine was intermittent, if you slammed the door hard sometimes it would reset for a while.
Post #648596 20th Nov 2022 9:40am
Thanks again…
We do them all the time! Just as common as on the 322 beforehand! NO they 100% do NOT need coding/programming sir…
Post #648600 20th Nov 2022 11:05am
kgeddes
Thanks Craig, can you give me a rough guide as to replacement price please? Many thanks Thumbs Up
Post #648616 20th Nov 2022 12:55pm
kgeddes
Can anybody give me the part number for a replacement driver’s door lock please?
Post #649209 26th Nov 2022 1:47pm
send Duckworths your vin Thumbs Up
Post #649268 27th Nov 2022 2:11am
kgeddes
Thanks Craig Thumbs Up
Post #649805 4th Dec 2022 11:25am
Post #649872 4th Dec 2022 10:40pm
