Home > Technical (L322) > Help me with the relay for cooling fan
Eddy
Italy 2012 Range Rover Vogue SE TDV8 Java Black
Good morning everyone,
Can anyone tell me where I can find the relay that controls the engine cooling fan on the l322 tdv8 4.4?
I'm desperately looking for it
Thank you
Post #649331 28th Nov 2022 8:06am
Eddy
I specify that I bought it but I don't know where it is in the engine compartment
Post #649332 28th Nov 2022 8:08am
GraemeS
Australia
According to the wiring diagram the cooling fan is directly controlled by the ECM.
From the WSM:
For additional airflow through the radiator matrix, particularly when the vehicle is stationary or slow moving, there is an
engine driven electro-viscous unit. This unit functions as a normal viscous fan, but with electronic control over the level of
engagement of the viscous clutch. The ECM , which determines the required fan speed, controls the level of clutch
engagement. The ECM determines engagement based on the coolant, ambient and transmission oil temperatures and A/C (air
conditioning) system pressure. The fan is mounted using a LH thread.
The viscous fan unit is electronically controlled by the ECM to optimise fan speed for all operating conditions.
Post #649334 28th Nov 2022 9:04am
Eddy
Do you think the control unit acts directly on the viscous coupling without an intermediate relay? My problem arises only under load and off road: iidtool gives me error P 0480 - 13.
How can I check the wiring - does anyone have a schematic
Post #649339 28th Nov 2022 10:07am
GraemeS
Australia
Correct, there isn't a relay for the fan. It gets power from fuse 20 in the engine bay fuse box.
https://www.fullfatrr.com/gallery/albums/u...ntrols.pdf
Post #649342 28th Nov 2022 10:30am
Busarider
Canada 2012 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Hi, new the site and I’m having the same problem with the same code P0480-13. Was this issue fixed? Did you replace the viscous fan or was it electrical related?
Post #651010 17th Dec 2022 6:59pm
