Home > Technical (L322) > Steering wheel goes all the way down on start?
Danwilderspin
Afternoon all,
I have a problem - when I start the car the steering column goes all the way to the bottom I can move it back and save the setting in the seat memory but when you turn it off then back on it goes to the bottom every time?
1) any ideas how to fix this properly and or the cause?
2) if a proper fix is costly and time some any idea where the plug is for the tilt and extend motor so I can just disconnect at the right height?
Cheers Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #681403 29th Dec 2023 12:35pm
Danwilderspin
Sorted - iid tool let me code out the easy access so it doesn’t mess about when you lock or unlock which works great for me Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #681453 29th Dec 2023 11:59pm
I was just about to say the same thing Dan... Always turn these off so they don't try & destroy themselves Shocked Exclamation Thumbs Up
Post #681457 30th Dec 2023 12:26am
