![]() | Home > Technical (L322) > Triple whammy - extreme cold |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 303 ![]() ![]() ![]() |
The temp sensor fault is a known issue, there’s a whole thread on it below and some debate about where the sensor causing the issue is located ( there are two viable candidates ). I’ve got this fault code too; most owners seem to choose leave it alone if there is no other fault as access is difficult. I might tackle it next spring.
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 66 ![]() ![]() ![]() |
I'm actually not that far north.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1399 ![]() ![]() |
Statfjord?
Forgot to say, battery probably needs changing..... |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3304 ![]() ![]() ![]() |
I’d caution against forced regens and especially any DPF cleaners which can raise the temperature of the DPF too much and cause permenant damage ( melt the metalic catalyst infront of the ceramic filter) I’d suggest a 20min drive in those extreame temperatures is simply not enough to initiate a proper regeneration. 2012 TDV8 Vogue (L322) |
I can see Statfjord from my office window, so you're not far off! ![]() Weather out here is windy, but (offshore)nice. And no, I'm here for both xmas and new years.! Thanks though! |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1412 ![]() ![]() |
Jaygee has a point regarding your journey, see extract from WSM-----Exhaust System - TDV8 4.4L Diesel
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you had an iid tool, you can do a forced regen, and set up the phone to monitor the parameters that the car needs to carry one out. ie you can see the soot levels, and engine temp, and speed. and by glancing periodically you will notice the soot level start falling. therefore maintaining the 25 mph will see it complete. also, remember that you need more than 1/4 tank of fuel for it to start. i had a red alarm, and used this method to get it to clear. ever since, when i get the amber, i go for the drive, and it clears. all without need for the tool. |
I do indeed have an IID-tool, but I couldn't find any forced regen functions in the menus.? |
The Wiki on this forum is amazing. A bit huge though, so thanks for the summary. My drive (to pick up the missus) lasted more than an hour, with a five minute stop in the middle to pick her up. It's 20 minutes each way. And I started off with a nice and toasty heater (warm engine). I can't get my head around why I wouldn't have regenerated. I've had some suspicions towards the battery; even though I changed it in February, it suffered a complete discharge after my mother borrowed it, left it with the blower at the rev limit (it has a dodgy hedgehog relay) and failed to tell me.. I charged the battery after this, but I notice when I switch EVERYTHING on (seat heaters, front and rear windshield heaters, blowers front and back on max) there's some fluctuation in voltage. It could be the culprit, and I think I'll change it once I get the car running again. |
You need to update to the latest software as it was a special request feature on previous versions. Once the DPF is past a certain soot load this is your only option but try a longer journey first if the warning is not telling you to go to a LR service centre ( or some such wording) 2012 TDV8 Vogue (L322) |
Rangie says:
I hadn't read the last part of your post... How did you manage to get it driveable (to do the regen) when it had the red warning? Mine's in restricted performance and won't let me get "carried away"... I pulled up some live values on the IID when I got back home though, and noticed exhaust temps were climbling past 500 degC when it parked it. I wasn't sure this was a good thing (hadn't studied DPF regen procedures or parameters before this happened) so I switched it off, thinking the temperature was too high because of a blocked DPF. Plus I was mega stressed because I had to catch a train to go offshore.... Hmm... Maybe I'm not in as bad a place as I initially thought then. |
If it’s on the ‘return to dealer’ a forced regen is your only option. 2012 TDV8 Vogue (L322) |
