![]() | Home > Technical (L322) > Jumping start from starter |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
All I know is that I use the left one 🤣 so dug out a pic, it’s the white one my CTEK adapter uses.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
I reached this point today also. It does work but you have to be determined. Get the emergency key blade out of the fob. Fully insert it into the slot under the cover on the passenger door. Twist it toward the door whilst pulling top and bottom on the cover with the other hand. It will come off exposing the barrel lock. Now unlock with the key blade so that the other doors & bonnet can be opened from inside. I was not able to jumpstart but I don’t understand why. I’m now on plan B which is to remove the battery and charge it out of the car. I’m not able to run the charger to the car as it’s on the opposite side of the road to my house but I have charged in-situ before and that has worked so it may be an option for you. TDV8 4.4 2012 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Pin 4 +ve pin 3 -ve BMW i3 Electric Car
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 430 ![]() ![]() ![]() |
Am in.
This mechanism is broken for me. Common issue it seems.
