| Arch, did you check your system voltage?
 It needs to be around 12.5V or better in my experience. All my early woes were down to a weak battery.
 Turn off all unnecessary electrical equipment, and maybe put a charger on if needs be.
 Having said that, my car has done the updates like clockwork now for over a year, but I had one fail recently or rather fail to start, and ended up with no maps installed whatsoever! -I re-downloaded the file and tried again and it worked, so I think you’re right in that files can get damaged and fail the checksum due to the huge download size and time taken.
 I have two super-duper Sandisk Ultra Flair 64Gb sticks which I alternate for maps anyway, so I can revert to an older, working map if needs be, I think this is a good/prudent idea.
 Good luck!
  V6 Vogue - “Less is More” - less to go wrong! |
