Home > Technical (L322) > Range Rover 2010 5.0L V8 Trolley Jacking Points
bearhouse
United Kingdom 2010 Range Rover Autobiography 5.0 V8 Santorini Black
Hi All,
I'm trying to understand where I can safely lift the car using a trolley jack. The attached shows the front and rear areas to position a trolley jack but I don't really see where these areas are from the drawing. Does anyone have actual photos of the underside showing the precise jacking locations.
I have side steps which means I can't easily use the regular jacking pads.
Many thanks.
Regards,
Post #652933 8th Jan 2023 7:29am
sako243
What are you trying to achieve, lift the body or lift the wheels?
I've never had an issue with jacking under the lower wishbones. My trolley jack sits neatly into the cup where the bolt goes so no risk of sliding off. Ed
Post #653049 9th Jan 2023 8:49am
bearhouse
Many thanks for your reply. You couldn't send me a photo of where you mean could you?
Post #653050 9th Jan 2023 8:57am
Re: Range Rover 2010 5.0L V8 Trolley Jacking Points
I just used to leave the backdoor slightly ajar so that the steps stayed deployed and used the std jacking points. Simples. Doesn't work with soft close on the 405 obvs! Mike - MPx
Post #653056 9th Jan 2023 11:03am
sako243
It's very obvious if you get under the vehicle. Right in the middle of the lower wishbone on the rear there's a recessed hole with a socking great big nut on it that's what I'm on about. Ed
Post #653106 9th Jan 2023 8:18pm
