Home > Technical (L405) > P400E hybrid. How to BLOCK engine charging battery .
Dan_Veluwe
Netherlands
I thought I worked it out.. .. but I did not.
The last few miles to my home are through a forest. At night I always go slow there, like 40 Mph.
This to reduce the risk of driving into wildlife. At lower speeds they mostly have time to jump away.
Some time ago, I noticed fuel consumption going to 18 L / 100kms at this speed, normal around 5 L /100km.
I switched the infotainment to 'My EV' and realized the engine was charging the battery at 10x the cost of
what it would cost me from the grid, like 6 miles down that road ! Evil or Very Mad
I thought I worked it out, by pushing the start/stop and blocking this function, it worked.. .. once ..
On another forum I learned BMW has a setting to prevent this in the cockpit controls.
Anybody has some help on this ? Maybe the dealer can do it by blocking it in the engine management ?
Very annoying this.. Rolling Eyes I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
PHEV P400e Hybrid Autobiography Loire blue= SOLD
D5 SD4 HSE Lux Corris grey = SOLD
D3 TdV6 HSE Lux Vienna Green =SOLD
P300 F-Type 2018 Ultra Blue = SOLD
25t F-Pace 2020 Loire Blue = SOLD
Post #657599 23rd Feb 2023 8:02pm
ilard
I think there must be some misunderstanding. Any engine output that recharges the battery is normal, excess energy. The engine revs are the engine revs for the speed and engine/coolant temperature, so there is no excess throttle inpu (i.e. revs) that would cause higher consumption based on battery charging. The primary source of battery charging while driving ways regenerative braking (not using the pads/discs but instead some dynamo gizmo to create drag and so a battery charge). Maybe less trust in BMW forums is the answer?! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #657607 23rd Feb 2023 11:09pm
Dan_Veluwe
Netherlands
Nope. I understand it perfectly well, with help of the fuel consumption meter, and the My EV display.
I come off the highway, a blast for almost one hour going almost 90 MPH constant. Then I turn off,
go into the forest and drive 40 MPH. In front of my eyes, consumption shoots up moments after the
'My EV' gets the battery turn green, and the "0 KM" EV range steadily increases with about 1 km per
3 km driven. Its evident : its charging the battery as if I would instruct it to "save" , which I did not..
Try it once with your car. With "0 kM" EV-range and the My EV screen on, watch you fuel consumption
once you drive 40 MPH.. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Post #657616 24th Feb 2023 1:31am
