Home > Maintenance & Mods (L405) > Looking for solution for obscured reverse camera
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I'm in the process of mounting Jerry Cans on the rear of my L405. Unfortunatley my reverse camera will be obscured. Whilst I can get a full aftermarket solution including its own screen, just wondering if anyone can suggest a more elegant solution? For example, would it be possible to wire a second camera into the car's system and switch between the two?
Cheers
Post #657793 25th Feb 2023 7:29pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Could you put the spare fuel on the roof using a rack and roto-pax system instead?
A friend of mine in Lethbridge has done that with all his Land Rovers and Range Rovers.
 Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #657884 26th Feb 2023 7:32pm
Salsbury
You are 100% correct, however, I am keen not to put anything on the roof this time round. Creates too much wind noise, increases fuel consumption and doesn't contribute to handling. Furthermore, I want to enjoy my glass roof!
I looked at Rotopax but they are on the small side (good for Quad bikes and chainsaws). The largest unit is 15L. I got a 30L unit from Aliexpress (rotopax inspired design) which is built like a tank!
After a bit of research, a solution might be a rear camera with a display the clips over the top the rear vision mirror. But as you well know, in Canada the challenge is keeping cameras clean in winter.
Post #657887 26th Feb 2023 7:51pm
Bora20
I hear you. I want to update my camera housing with the sprayer from the later models. I will do it when it warms up.
Can you mount it using a custom hitch mount to keep it low? It wouldn’t flip around if you use a hitch spacer (Princess Auto) that holds the receiver right in the hitch. I have used a similar system for my hitch mounted dirt bike rack. Even a basket rack might do what you want. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #657889 26th Feb 2023 7:55pm
Salsbury
I'm working with a fabrication shop to build a hitch mount solution. Swing down style. Will post pictures when finished.
Post #657890 26th Feb 2023 8:02pm
