| TDV8 4.4 whooshing then limp mode (restricted performance) | |
I wonder if someone could advise where to look.
Our 2010 4.4 tdv8 - I've had a bit of a mare with sorting out a leak from the intake boots - so they've been replaced with silicon jobbies now. I then had problems with an ill-fitting fuel filter, then the wiring to the filter assembly finally sorted out the intermittent amber restricted performance issues.
I then had a two water leaks - they've been sorted and for two days we've been happy. various runs out/starting/stopping etc etc and all gravy.
Tonight, just as confidence was building we filled up (100 quids worth) of morrisons diesel, drove about a mile then turned right and we got a "whooshing" sound, then it hunting a bit, then pinged up red restricted performance and whilst runs/idles just fine is now restricted to under 2,300 rpm/30mph.
I checked errors on the GAP - nothing untoward - the EGR (common) shows, but this has been on forever, anyway - cleared that, but red restricted is permanent and cant be cleared.
I left the car for about half an hour, went out and checked my hoses were all tight, had a small suspicion that the rear left one wasnt quite tight enough, started it up and no errors, and can rev freely.
so, I then took it up the road, revved it up/gave it a bit of welly and all is fine, however after about a mile or so this "whoosh" and then the same thing again - running lumpy, then red restriction. the sound is like a high speed expression of air with a bit of a whistle with it.
again, no untoward errors.
I dont really see where to look, but it sounds like a pipe is popping off when its warm, but that doesnt sound plausible, and if it pops off when warm, what pixie comes along when the cars cooled down a bit and popped it back on?.
has anyone had similar?
Cheers in advance,
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
