![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Also is there any way to do a full complete utter reset on the car?
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
My understanding is that disabling DCS should disable the CVD system therefore give a harsh ride. If no different, then that suggests that it’s not disabling CVD system as I understood, or you do have issues! Maybe unplug a shock..l even if just to prove or disprove that? It’ll help get nearer the issue, or knock something off the list! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Can meet you somewhere near Doncaster if you want a comparison... |
I know Graemes on here has always said disabling DSC makes the shocks stiffer but that was on a 322 so not sure if it applies here.
Never heard of any way to do a total reset, maybe there is a software update for the suspension available... Pete
Actually that's made me think of something Haylands... wonder if LR did some sort of update on the suspension ecu when they fitted the new compressor? |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 136 ![]() ![]() |
That could be the issue in a roundabout kind of way. Different manufactures make the same pump that need their own software to run properly. Maybe they did not touch the software but put a different make of pump in? X5 40d |
You have an IIDTool don’t you? I have various emails in my inbox with s/w versions shown. If you have one it’ll give you that answer… If not, it’ll at least show you if any updates are available… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Wasn’t there also a step where you (with the battery disconnected) touch the leads together for a minute? It was described to completely drain all systems of power iirc Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Good thought evo, I'd expect some sort of warning or fault to show if that was the case but you never know.
No warning light. I only know as I watched a video the other day on the very subject on youtube. He coded the correct software to the pump with IID tool. Will go see if I can find it. X5 40d |
Well, ahem! To prove my theory, unexpectedly! I had my 405 on the local hunter machine last week as I felt the car pulling every so tiny bit to the right! Haven’t driven it since. Until today!!! I have been 55miles down the motorway today and well! OMG! It’s shiiiite! Ride is rubbish it’s vibrating all over the road! It’s fidgety! It feels like a damper has popped! I will get it on the ramp first thing tomorrow and report back! |
Well that's really interesting Craig,
Also to add I've just been out and done a full battery disconnect so that's both batteries unhooked both positive and negative terminals.
