![]() | Home > General > Vogue SE Cooled seats |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
there should be two twistable knobs on the dash with a seat picture on it and you turn in left for cooling (lights go blue) or right for heating(lights go red) |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
The knobs also have a pic of a seat bottom and back that illuminate and you can direct the cool air to either your back your rear end or both! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 ![]() ![]() ![]() |
My SC VSE dont have cooled seats |
Nor mine , but my windows open |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Wasn't it 2007 on that got perforated seats 'n' cooled tush? |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
That's what I thought. Basically, if you have a button for heated seats, you don't have cooled. If you have a dial for heated seats then it twists the other way to cool instead of heat. |
Kads Member Since: 08 Jun 2011 Location: Thurrock Posts: 30 ![]() ![]() |
Grrr |
So you stick your ar5e out the window to cool it like? ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Standard equipment from MY07 on Vogue SE and above. As others have said, the dial is the giveaway. |
I meant I put the window down if I want to let air in the car since I don't have cooled seats as a joke ![]() So why the ![]() |
Erm, no offence intended! It was your ar5e hanging out the window that was ![]() ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
No offence taken Al just curious , too old to get offended |
Cool! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
How easy it is to offend via email & forum posts........ |
