Home > Maintenance & Mods (L322) > Silly Question? Brake Fluid
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
My brake fluid holder does not a max/ lowest indication as far as I can see. Should the correct level be at the joint level on the top and bottom section of the container? Wondering if its too low as it is now.
I presume there would be a warning on the dash or should be if low.
Got some warnings up on the dash in yellow which I will be getting looked at a local garage next week.
Thanks
Post #668389 5th Jul 2023 11:13am
garyRR
Your brake fluid reservoir has a max marker near the top of the reservoir before the neck. 2015 Range Rover Autobiography 4.4 SDV8
Post #668398 5th Jul 2023 11:51am
Nylands
Thanks very much Garry I'll have another look. Have to say it's not in a very accessible position and it does need topping up then.
Cheers
Dave
Post #668426 5th Jul 2023 3:04pm
garyRR
I find that when you put the stem back in the level rises somewhat, so fill a couple of millimetres below the max marker. Once you put the lid back on, it should show nearly full.
If you need more space, you can put the bonnet into service position:  2015 Range Rover Autobiography 4.4 SDV8
Post #668427 5th Jul 2023 3:06pm
Pawl
As an additional suggestion :
DON'T top-up to the MAX line if your pads are already well worn OR you'll need to be prepared to siphon fluid out when you need to put new pads in.
The MIN line is there as an indicator of the MIN acceptable fluid level & not an indication that fluid needs adding. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #668460 5th Jul 2023 10:35pm
Good point, well made sir... Bow down Thumbs Up
Post #668465 6th Jul 2023 12:31am
Nylands
Thanks to everyone. I found the max line as said but wasn’t able to see the actual fluid level due to yesterdays light here. All was well when I rechecked and not therefore responsible for my dashboard warning lights. Got it in a garage next week for them to check them out.
Dave
Post #668494 6th Jul 2023 1:31pm
