![]() | Home > Technical (L322) > Drive Shaft Removal Tool |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
Check out Sykes Pickavant website, not cheap, but they sell some seriously good stuff.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
I’ve used a hydraulic one before for a stuck driveshaft. That pictured on will likely not be large enough and wil snap under high load.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
Have you got (or can you borrow) a big hammer drill - the bigger the better?
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
Update on this. In the end due to not wanting to damage the driveshaft with the lump hammer I have pulled the shaft complete knuckle/ hub out. Going to take the assembly to my local garage to press the shaft out.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
David did it with his early S/C... very similar to yours... |
Hi Pete,
Steve7678 Member Since: 06 Jan 2022 Location: London Posts: 5 ![]() ![]() ![]() |
try Roger Hutchings on Facebook (https://www.facebook.com/roger.hutchings.79) he makes a tool for removing the drive shaft that has been very successful.
