![]() | Home > Technical (L322) > Figure out if its been remapped? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
Try timing 0-60 on a 'dyno' phone app. Some remaps increase the torque significantly (and the way it loads up) which is the main issue with the drivetrain rather than HP. 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
ah nutty 800nm of torque or someshit is what they pretty much said.
Assume it is remapped and get it returned to stock if you are having gearbox issues and want to prolong it's life. 2012 TDV8 Vogue (L322) |
tbh with the gearbox feeling thuddy, in my head am budgetting in a replacement/rebuild already. Its actually a sport |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
There are other ways to hasten a MiL's demise. |
Fluid change and software update can help but depends on the severity of the harsh changes. Also if it's a crude remap it won't play well with the gearbox programing. 2012 TDV8 Vogue (L322) |
had a full flush recently thanks to Bodsy.
Byg Nyge Member Since: 31 Dec 2022 Location: Newcastle Upon Tyne Posts: 31 ![]() ![]() ![]() |
If its just a thud when putting into drive I'd suspect one of the several prop shaft joints, had the same on a Nissan Navara, it was the rear prop shaft U/J, later the same when a front prop shaft U/J spat the dummy out. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Press on the brake pedal harder before shifting into D. See if that makes a difference Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
huh that seems like a easy enough to do. will give that a shot thanks
