Home > Maintenance & Mods (L322) > CVD Rear Shock Replacement
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Good afternoon,
I will soon be replacing both rear CVD shocks because one is leaking. Should I also replace other components such as the Insulator/Mounting Bracket?
Any tips & hints are welcomed - many thanks,
Tom. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #671585 20th Aug 2023 12:42pm
mjdronfield
No, but the instructions say to renew the paper gasket to prevent moisture ingress into the cabin.
HW2 on the diagram.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #671588 20th Aug 2023 1:07pm
GraemeS
Australia
They are sold as complete units including the mounting bracket. I fitted Bilstein because they were significantly cheaper than genuine LR even though sourced ex UK.
Post #671589 20th Aug 2023 1:09pm
TDV8_Tommy
Thanks, guys.
I´m also going to use Bilstein, the cheapest I can source is coming in at €706 for the pair. Lovely. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #671592 20th Aug 2023 2:12pm
mjdronfield
I fitted Bilstein. You still need the paper gaskets from LR…. That didn’t come with mine.
Only a few pounds…. Other folk might have had then in their kit of course.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #671593 20th Aug 2023 3:00pm
GraemeS
Australia
As the gaskets aren't included in the component diagram for the shock I wouldn't expect any genuine or after-market shock to include them.
Post #671611 20th Aug 2023 9:47pm
JayGee
Just because it's leaking doesn't mean it needs replacing. There is a service buletin about leaks and the need to not be concerned. 2012 TDV8 Vogue (L322)
Post #671621 20th Aug 2023 11:02pm
TDV8_Tommy
Thanks, JayGee,
But this needs to be replaced. As I mentioned in another post, there is an obvious leak (not simply "misting") when the rear driver's wheel encounters a succession of rapid potholes or a poor road surface. The back end will violently drop on that side, causing a dramatic lurch at the front. It feels like the whole car is twisting. It's actually quite scary. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #671623 21st Aug 2023 7:10am
JayGee
That's called 'jacking' when the rebound damping is more than the compression damping and the strut effectively shortens. Mine have been damp for the last 2 years / 30K miles but still do their job and are now on 160+k miles 2012 TDV8 Vogue (L322)
Post #671632 21st Aug 2023 10:30am
mgrover
i used aerosus recently. worked like a champ.
also transformed my car. mine were so "empty" that you could push the dampers by hand very easily. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671637 21st Aug 2023 11:43am
TDV8_Tommy
Thanks, everyone.
"Jacking" feels like the shock collapses but recovers. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #671660 21st Aug 2023 5:36pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I've also got leaks and quite a compression rebound in both my rear shocks.
Anyone here in Canada/North Eastern US have a recommendation for a supplier, kindly do share your experience Smile 2012 Supercharged L322
Post #684761 5th Feb 2024 2:50am
TorontoDee
Bilstein's ordered for my MY2012 S/C. Air springs will be reused. Any pointers, thoughts, please share 2012 Supercharged L322
Post #685478 12th Feb 2024 8:54pm
