Home > Maintenance & Mods (L322) > Under bonnet rubber seals
P&D
Ireland 2004 Range Rover Vogue Td6 Sumatra Black
Hello all,
After years of talking about it, then weeks of reading through this forum and watching youtube videos, myself and my partner purchased an L322.
Its a 2007 3.6 TDV8 Vogue SE in Stornoway Grey.
I plan to post more etc once I sort out a few immediate issues.
One of those issues, is a lose scuttle panel with missing clips – Part number CYC000010 – which I will get from my local LR dealer – they can have them in next day, so as with being in Ireland it makes most sense.
Anyway, a part, or missing part,I am having trouble with is the rubber seals around the pinch welded sections that seal when the bonnet is closed.
I have looked at videos and pictures on line and some appear to:
- Have nothing (like mine)
- Others appear to have a short section of rubber (like the nearside on mine)
- Others have a strip from the start of the battery compartment right the way down to the end of the bonnet
I have what I thought was the correct part number CJE000052 but now it may look like it is in fact CJE000063
Does anyone have any idea why I am seeing such a difference in pictures and videos? Is it a common part to go missing?
I am seeing some water on top of the battery and it is from the windscreen run off over topping the lip as there is no rubber……
Any help is very much appreciated
Post #671756 22nd Aug 2023 2:02pm
Welcome to the club...
Ran fatty offroader for years without any, didn't seem to make any difference and I thought it helped with under bonnet venting...
You could use a generic seal, just put a "column" of blue tack along the top edge, close the bonnet and it will flatten to the height you require, well add a few mm to get some squish.... Thumbs Up
Or message Robin at Duckworths, our site sponser, he will know from your vin and give you a good discount with free postage (hopefully to Ireland !!) Pete
-Click here for Thread-
Post #671761 22nd Aug 2023 3:20pm
P&D
Thanks Haylands, appreciate the reply.
I did think of some generic type of sealing strip but wanted to see what other thought...
I have seen water top the rim into the battery compartment, infact, it had dripped directly on to the terminal.
Also when opening the bonnet, water makes its way into the compartment, is this "normal" ?
If anyone has a link to a generic seal that might do the trick, it would be much appreciated
Thanks once again
Post #671764 22nd Aug 2023 3:39pm
JayGee
I think it's more for sound insulation than any kind of engine protection from water unless you are wading through deep water and have a bow wave washing over the bonnet. Mine are perished and falling apart. 2012 TDV8 Vogue (L322)
Post #671768 22nd Aug 2023 3:47pm
garyRR
A quick search online of CJE00052 suggested it's a 30cm length. CJE00053 states 100cm, however the parts catalogue shows the part you have is defined by chassis number:
 2015 Range Rover Autobiography 4.4 SDV8
Post #671777 22nd Aug 2023 5:34pm
knotty68
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
The nearside rubber seal was split on my 2011 L322, I ordered the seal below from AliExpress (search Rubber Door Seal and I opted for D-11 type) for £10 shipped. Pleased with the fit.
Item link fwiw https://www.aliexpress.com/item/1005007776191241.html
Post #718218 20th May 2025 10:29am
robertcope
United States 2011 Range Rover HSE 5.0 V8 Ipanema Sand
I just ordered the part https://landrover.oempartsonline.com/oem-p...l-lr012017
It slips right off and back on. No idea what difference it makes, but I like my cars correct.
Post #718382 23rd May 2025 1:33am
p38arover
Australia
Were they something added to later cars? My 2003 doesn't have them. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #718406 23rd May 2025 12:25pm
robertcope
Well... the part number that I ordered is apparently for 2010-2012 models. It looks like earlier models had a similar seal but with a different part number. <shrug>
robert
Post #718414 23rd May 2025 1:20pm
