Home > Technical (L322) > High beam LED and MOT
JayGee
Fitted these a while back and they are fantastic at illuminating dark country lanes but technicaly they won't pass an MOT but has anyone had an actual fail because of them? 2012 TDV8 Vogue (L322)
Post #671852 23rd Aug 2023 5:04pm
garyRR
I think most MOT stations won't care, however I have previously had a car fail due to LED bulbs in incandescent fittings. 2015 Range Rover Autobiography 4.4 SDV8
Post #671856 23rd Aug 2023 9:32pm
mjdronfield
I had no issue. Which ones did you get?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #671858 23rd Aug 2023 9:34pm
Ennoch
Some MOT testers are more lenient than others. High beam and low beam are quite often different in how they're approached, and whether or not they're fitted within a projector or a reflector housing. A mate of mine is a tester and is certainly one of the more pragmatic ones, if not actually massively lenient. However, even he would fail an LED in a reflector housing. As long as it's not obvious (i.e it's in a projector housing) and especially if it's high beam, I can't see anyone but the most yellow jacketed power tripping tester to have any issue.
Post #671873 23rd Aug 2023 11:24pm
DrRob
Passed with no issues here. Old ones in the boot on the day in case needed to swap out Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #671888 24th Aug 2023 8:20am
JayGee
Same as you recommended a while back I think Thumbs Up
I've got the old ones in the boot and may just pop them back in to avoid the (small) risk of a retest and another £12.50 ULEZ trip back to the garage.... 2012 TDV8 Vogue (L322)
Post #671890 24th Aug 2023 8:36am
JayGee
Passed with the LED's Thumbs Up 2012 TDV8 Vogue (L322)
Post #672398 31st Aug 2023 8:35am
