Home > Technical (L322) > Suspension
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Suspension
Weird one today, jumped into the car , message on dash to close doors to change suspension!
Car is in normal height, wont go up or down?
Switch changes between hi and low but no movement!
Any ideas guys
David 2014 vogue se
Post #671925 24th Aug 2023 3:20pm
Tiprat
Mine 2007 Vogue did similar things awhile ago it turned out to be the air tank under the sill. It was rusty and leaking so couldn't keep enough pressure in. However before I realised that I changed the air compressor because it had failed due to running constantly. The tanks changed from aluminium when BMW were in charge to mild steel when Ford took over. Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #671978 25th Aug 2023 10:57am
mjdronfield
As it’s saying close door…. It thinks a door is open so locks out suspension movement. I get the tank could be an issue, as mentioned above, but why would that make it think a door was open?
Does it think a door is open all the time? If so, the alarm won’t set etc….
Strange if it throws a door open message if it’s not, but then these cars do strange things sometimes 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #672001 25th Aug 2023 2:44pm
JMC
I'm with MJ on this! The car thinks a door is open, ergo it won't raise/lower. Simples....ish! Just need to find out which door is causing the issue and rectify it. Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #672002 25th Aug 2023 2:58pm
chefkenmore
Well, well!
Didn’t take the car to work today! Used the mini, came home, unlocked the car, fired it up and all back to normal!!!
Don’t we just love these beasts?
Thanks for the answers Thumbs Up Thumbs Up 2014 vogue se
Post #672009 25th Aug 2023 3:44pm
