![]() | Home > Technical (L322) > lights |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 158 ![]() ![]() ![]() |
Hello everyone
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Sometime working, sometime not. Bad connection or something... |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
Take the respective bulbs out and clean them with fine emery paper, probably minor corrosion. |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Sometimes these can warn you of a bulb is on its way out, the filament might be intact but the car is not detecting the correct voltage coming back because the filament is dying and causing extra resistance on the circuit 2009 (2010 MY) 5.0 Supercharged Autobiography
