![]() | Home > Technical (L405) > Can a L405 be towed |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Just watched a video from 4XOverland on youtube about issues with new Defender, one being it cant be towed as handbrake automatically comes on after 10mins. Is this the case with a L405? 2007 TDV8 VSE
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
He is right the electric brake will come on if it's not put in 'N' before the engine is turned off.
As the man says its unbelievable that an "offroad" vehicle cannot be towed out of an offroad situation.
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
You can tow it (recover it from an off road situation) as long as the engine is running though, surely? in which case the vehicle would presumably be in gear (forward or reverse) ready to try and move under its own steam FFRR SDV8 Autobiography |
You could simply pull the gearbox neutral release and with the handbrake in the off position, unplug the handbrake motors behind the rear calliper's... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
Mine doesn't automatically apply the EPB. It's a CCF option that isn't enabled on mine. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
I leave mine in the garage with the HB off, I hold the park Brake lever down until I switch the engine off and this keeps it off.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
If you pull the park release, I can't see that it's much different from any other automatic 4x4 - if you flat-tow it for any distance with the props connected, you'll destroy the gearbox anyway. |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 242 ![]() ![]() ![]() |
I always leave mine in the garage, in park. The handbrake is off. Is this correct. My garage is level. 2013 SDV8 4.4 SE Luxor.
Also, that 4xoverland bloke has a massive chip. Most odd. |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Or you could follow the manual ![]() EPB CAUTION: This procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine must be OFF) and the parking brake system released. NOTE: This procedure allows the parking brake to be released when recovering the vehicle. Activation 1 Press and hold the parking brake switch in the release position. 2 Wait 2 seconds. 3 Press and hold the accelerator pedal in the wide open throttle position. 4 Wait 2 seconds. NOTE: 5 An audible noise will be heard to confirm that the parking brake has been released in Service Mode. Turn the ignition Off and back On immediately. 6 Release the accelerator pedal and release the parking brake switch to the neutral position Deactivation CAUTIONS: This procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine must be OFF) and the parking brake system in Service Mode. Once the vehicle has been recovered, the Service Mode must be cancelled. NOTES: If this process is followed, new electronic park brake actuator O-ring seals are required. To be carried out in the event that the vehicle has no electrical power. 2018 SE SDV8 4.4 Byron Blue |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1091 ![]() ![]() ![]() |
On a shooting trip a while back, I had to be towed out (wet grass, adverse slope and road tyres…..). The front valance was removed, a rope attached to the towing eye and then attached to the gamekeeper’s Defender. Engine running in my car, left in neutral and pulled away. Once on level ground, engaged park, removed rope and proceeded normally (GGS engaged, low range just to be sure.). |
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 111 ![]() ![]() ![]() |
Full of it, he is. |
