![]() | Home > Technical (L322) > Glovebox light |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Bought a LED interior upgrade kit and noticed the glovebox light is missing, most of the vids I have seen show the older models that have the on off plunger switch attached to the light itself.
Photos attached |
Thanks for the info, most of the lamps I have seen for sale have the on off plunger on the light unit itself. Those must be for the earlier models I guess. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
You can carefully remove and replace the bulb with a pair of long nose pliers. On a 2010, the bulb is a W5W. 2015 Range Rover Autobiography 4.4 SDV8 |
