![]() | Home > Maintenance & Mods (L322) > 3.6 TDv8 Engine ECU Software / Long distance fuel economy |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
Any input please ? A bit of a long thread I'm afraid....
JayGee,
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
A 60 profile is nearly 7% bigger than stock so your mpg calculation will be well down and also your speedo will be under reading significantly. The difference between driving at 65 and 75 will have a significant improvement in mpg due to the wind resistance changing exponentially with speed. No need to have a working fuel gauge as you just fill till the autostop on the pump and reset the trip then refilll to the same and record the trip mileage and do the maths. 2012 TDV8 Vogue (L322) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3275 ![]() ![]() ![]() |
Personal opinion but I rarely use cruise control. I find it a pain as in traffic you are consantly checking speed because the speed of person in front of you is rarely constant ( adaptive cruise control might overcome that). I also don’t find it to be an economical mode. Better throtle control without it.
Cruise control is not meant to be used 'in traffic' for safety above all else hence why adaptive systems are now the norm which can adjust the speed and automatically brake. 2012 TDV8 Vogue (L322) |
I understand that. I am talking about motorway use. John
So am I and I only use cruise when it's very quiet. 2012 TDV8 Vogue (L322) |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389 ![]() ![]() |
Hello Paul.
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 ![]() ![]() ![]() |
I have owned my FF over three years now and using it daily around town it averages 22/23 mpg and on a long motorway run she will hit up to 32mpg. I blanked the EGR's off about a year after I bought it but didn't notice any difference to the fuel economy at all. It's a heavy vehicle with the aerodynamics of a concrete block so I never expected it to be economical, just the most comfortable vehicle I've ever owned. My advice is to look after and enjoy what you have! Current collection :
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Use mine all the time. I'd even use it coming off my 20 meter drive, if I had the time😉 Previous cars: S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?) Galaxy 2001-2007 Mondeo Estate 1997-2001 Sierra Estate 1993-1997 Uno Turbo 1987 -1993 Fiesta 1984 - 1987 Fiat 127 1982 - 1984 |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176 ![]() ![]() ![]() |
Mine is a 07 tdv8,140k old. Averages 24+ all local short journeys unless trip computer is wrong. Stock car, no egr blanking/mapping etc.
Average mpg is also very much down to how it's driven. Always accelerating 'briskly' and cruising above 70mph on the m-way will hit mpg hard. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2765 ![]() ![]() |
Standard L322 is either 255/55R19 or 255/50R20, both 30" nominal and standard L405 is 255/55R20, 31"nominal. You might need to re-adjust your distance travelled. I have 255/60R19 (31" nominal) and increase my distance travelled by 3.5% for calculations. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Another user here of adaptive cruise control all the time. Takes the effort out of long distance motorway journeys especially when heavy traffic. |
