Home > Technical (L322) > Different size spare to rest of alloys, will it work?
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Hi, just noticed that although my spare looked 'at first glance' to be identical to the other four alloys on the car it actually is not !!! Censored
So i have four 19'' alloys on the car but an 18'' as a spare. Will this work as an operational spare or will it mess the 4x4 system up? 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #73537 24th Jul 2011 7:40am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Yes, if the diameter of the wheel and tyre is the same
i.e a 255/55r19 is 30" diameter and a 255/60r18 is also 30" so that combination would work.
get the tyre sizes and use the calculator on Difflock.com (sticky on tyre section) to check.
Post #73556 24th Jul 2011 12:39pm
wedgel322
Thanks for advice, i will check it out 2003 Range Rover HSE 3.0 TD6
Post #73592 24th Jul 2011 6:24pm
SteveMFr
Site Sponsor
http://www.1010tires.com/tiresizecalculator.asp
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #73603 24th Jul 2011 10:53pm
you'll find loads of members have upgraded from 18''/19'' to 20'' but have only brought 4 wheels so the spare is still the old size [like me]...i luckily find out in time that my 18'' spare had to use the smaller black nuts whereas my brought 20'' had to use the newer larger silver nuts...so had i had a puncture the spare would not have fitted, when i realised i put a set of smaller nuts in with the spare, just in case i needed to use it..
Post #73614 25th Jul 2011 9:44am
In theory you can run the car on 18s, 19s and 20s all at the same time as the rolling circumference is the same (within tolerances)
Having a different size spare is no problem Discovery 4 HSE
Post #73624 25th Jul 2011 10:07am
