Home > Technical (L322) > Eas fault ? Door lock
Bigstu
England 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, new member so go easy on me Wink
I have an l322 02 4.4 petrol and have a couple of issues
1st NSF door started playing up and not unlocking itself when the key was pressed
You can hear the motor trying to push the pin up but 9 times out of 10 it stays flush with the door card and won't unlock the door. I have sprayed ptfe type lubricant down the pin but no joy. It has now started to not even pop the button up when pulling the interior door handle. New lock ???
I was going to wait until I could find a new lock cheap but I think it may have started another problem !
2nd air susp inactive message on dash. The airbags are still inflated so no leaks checked the pump etc all seem ok
. It seems like a soft fault as the height indicator on the panel is lit but won't allow any height change.
Could this be related to the door fault ?
The fault just pinged up after parking the can no speed bumps etc
I am a Vauxhall tech but my code reader won't access the eas system
Any ideas guys?
Any local code reader owners local to stanfordmle hope in Essex
( will the eas ecu reset if it is the door lock causing the fault and remove the message from the dash ? )
Thanks in advance Thumbs Up
Post #73567 24th Jul 2011 3:38pm
JustinP
Hi Bigstu,
Welcome to the fullfatrr forum Smile
Regarding your Air Suspension Issue, you may be able to clear it by Starting up the engine and then turning the steering wheel all the way to the left then all the way to the right.
Post #73568 24th Jul 2011 4:15pm
Bigstu
Hi, tried that thought it only re calibrated the steering angle sensor but didn't work anyway lol
Post #73576 24th Jul 2011 4:50pm
sometimes dis-connecting the battery re-sets the ecu's...
Post #73587 24th Jul 2011 6:03pm
The side door latches incorporate a sensor to provide a door status signal to the BCU.
The EAS is inactive when a door is is sensed as being open.
I think your door latch / acutuator unit apparently being faulty could be linked to your EAS fault ie the "Air Suspension Inactive" message.
The same message appears when you leave a door open by mistake.
(How do I know that? Embarassed )
I would concentrate on the door lock if I was you before worrying about the EAS "fault".
Hope this is of some help.
Post #73594 24th Jul 2011 8:34pm
that makes a lot of sense ... Thumbs Up
Post #73615 25th Jul 2011 9:45am
Bigstu
Fitted new door lock only took 5 mins max
Locking etc all working now BUT !!
The air susp inactive message still on dash and now don't have any lights on the adjustment panel !
Do I need to reset the ecu or something ? Big Cry
Post #73834 26th Jul 2011 6:19pm
did you do this?
Post #73836 26th Jul 2011 6:33pm
Bigstu
Yeh tried it before I replaced the door lock will try it again
Post #73844 26th Jul 2011 7:21pm
Bigstu
Didn't work again.
I unplugged the compressor before I changed the door lock would that now put the ecu into hard fault ? Will it req a reset ?
Can I power up the compressor from the plug to check it works etc ( anyone got a wiring diagram )
Looks like a trip to an Indy how much ave is it for a code readout ? Anyone recommend a local Indy garage near Basildon / grays Essex ?
Post #73864 26th Jul 2011 9:25pm
Bigstu
All sorted went to Fortune 4x4 in laindon to get a code read out compressor overheat codes was all reset and light now off etc
Guys said may last years may come back on next week didn't try and sell me the compressor or push me into getting it sorted
Can't recommend these guys enough Bow down
If anyone is getting problems with there RR in the south Essex area I would defo give these guys a call
cheap diagnostics charge swell Wink
Post #73933 27th Jul 2011 6:10pm
why did you disconnect the compressor stu?
Post #73934 27th Jul 2011 6:11pm
Bigstu
I disconnected the wiring harness in the spare wheel well to check for a live feed and see if I could check the can bus lines etc but I think the ecu shut the system down so didn't get an plausible readings
Post #73938 27th Jul 2011 6:38pm
understood. Thumbs Up ...
Post #73979 28th Jul 2011 7:48am
