Home > General > Newbie seeking wisdom of the crowd - first purchase |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1260 |
Good luck with your search, I can't help with the diesels, but if it supercharged I can definitely help. L322 or L405 you wont be dissapointed. I have to ask, if only 3k a year why on earth don't you go for a Supercharged, you will have less issues in my view and the smile will be just as big if not bigger.
16th Sep 2023 10:12pm |
T4ls Member Since: 09 Sep 2023 Location: Berkshire Posts: 16 |
Very valid point. I’ve certainly been keeping an eye out for the supercharged as would certainly buy one given my intended use, but haven’t seen many up for sale that fit the bill from an l322 perspective.
16th Sep 2023 10:38pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
I bought a 2011 at 83,000 miles and now on 124,000. Just had normal servicing and all oils changed (g'box, transfer etc.). Only fault was the inlet manifold cracked (inferior LR part, now improved) at 100,000. rest was mainly wear and tear such as suspension arms replaced, tracking. Other than that all good. |
17th Sep 2023 1:25am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
I think JLR say 100k or 10 years have all the oils changed, gearbox, diffs, transfer box etc etc. usual suspects are oil cooler leaking (£700 inc labour approx) starter motor goes sub 100k. Suspension legs start to feel weak sub 100k, but to be fair to the RR, it’s similar to any other car, it’s a combustion engine powering transmission…..looked after, she’ll be fine.
17th Sep 2023 10:31am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
If you are only doing 3k per year and have a flexible budget then defo think about the 5.0SC. There isn't a switch that flips when you go over 100k but these are now all old cars at whatever mileage so ignore everything else but the condition and have it expertly inspected. 2012 TDV8 Vogue (L322) |
18th Sep 2023 7:12am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4240 |
I'd avoid a 4.4 TDV8 at that proposed annual mileage. They need long runs as they have a DPF.
18th Sep 2023 9:42am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
Buy a petrol they go on forever |
18th Sep 2023 12:05pm |
Thanks all for the guidance.
18th Sep 2023 2:46pm |
17th Oct 2023 10:03pm |
Looks lovely and nice to see another one without the rear privacy glass. 2012 TDV8 Vogue (L322) |
18th Oct 2023 2:05pm |
