|  | Home > Technical (L405) > Rear Diff Failure |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210      | My Diff is being replaced as I write, it may not be the same as yours as its a AB which has the clutch pack inside, mine is under JLR warranty.
|  6th Nov 2023 6:02pm |
| Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 200      | The rear diff on my 2016 Vogue failed (noisy and leaking oil from the front pinion seal) earlier this year after only 41k miles. Replaced the whole unit under warranty. I think it is a relatively common issue. | ||
|  7th Nov 2023 9:04pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
