![]() | Home > Technical (L405) > All I want for Christmas..... is a new Engine |
nike_bytom Member Since: 29 Mar 2025 Location: Thrapston Posts: 27 ![]() ![]() ![]() |
Hi all, quick update:
Hi,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2768 ![]() ![]() |
Check the front main journal for taper. L405 D350 SE Carpathian Grey D5 19" rims |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
I suspect the last person who was in there wasn't too good at rebuilding engines! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
waltsworth Member Since: 30 Aug 2025 Location: Norwich Posts: 1 ![]() ![]() |
Hi 4RRS, read this write up with great interest, I have an identical issue, spun no.3 bearing and now need to follow the rebuild path. Engines out, we can see the damage, luckily this all happened while car was at a standstill, so when it started squeaking then knocking we could turn it off to prevent major damage.
AussieV8 Member Since: 04 Jul 2025 Location: Maitland Posts: 7 ![]() ![]() ![]() |
I've just finished assembling my 448DT in a RRS sport. Same thing number 3 main. When we were working on the tunnel. We found when pulling down the main caps the tunnels were distorted. Number 3 the most then number 4. We pulled them down then re cut the tunnel to suit the bearings and get the right crush. After that I assembled and then plastigauge the crank 3 times. 0 degrees. 90 degree and 180 degrees. That will tell you if it's bent. I used king bearings. The clearness were to tight for my liking so I polished the crank until all mains were 2 thou oil clearance, that's not a recommendation. Just what I did.
All I can offer is that I persevered and found a secondhand good crank from an L322, mated with std size King bearings it's now nearly 60k miles in and running great. I saw some cranks recently on eBay that had been ground, one I think the mains and one the big ends, again not ideal but maybe better than aftermarket. I've not seen any posts from members that have used aftermarket and reported on reliability, so it's an unknown gamble to my mind! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
