![]() | Home > Maintenance & Mods (L322) > gear changes |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Definitely worth reading the solenoid adaption values, if you have suitable diagnostic equipment, to see if any are extreme (i.e. >300mbar) as this would give you an indication if any solenoids were faulty. Failing that, you could just risk going ahead with a new solenoid set (ZF p/n 1068 298 044) which costs around £280 : https://www.sussexautos.com/products/6hp19...68-298-044, especially if they’ve never been replaced before.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 589 ![]() ![]() ![]() |
hi yea i have the gap tool ....will i find the reading in the live data(fairly new to range rover/gap tool world) and would you suggest getting gearbox upto temp ? |
The gearbox temperature doesn’t matter because the adaption values are determined over a long period of time. I don’t own an IIDTool or a Range Rover (any longer) so others would be better placed to tell you how to drill down through the menus to find this data.
Is this what I should be looking at ?
No, those are the live values for the solenoid currents. You want ‘transmission fluid filling pressure for adaptions’ and ‘transmission fluid filling time for adaptions’
ah right ok ill have another look .... |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Are adaption values the car adjusting to driving style, or adjusting to gearbox variables/wear ? |
Good question-well asked …..pass lol I don’t know still learning myself |
The latter. Adaptive Shift Strategy allows the transmission controller to talk to other vehicle systems to determine the way in which the vehicle is been driven. This is forgotten when the ignition is turned off. The solenoid adaptions are calculated/accumulated over the lifetime of the vehicle (i.e. over a period of years) where the controller tweaks the solenoid currents to maintain shift times and quality, to take account of gradual wear in the system. These adaption values should not therefore be randomly reset unless a major change has taken place e.g. new solenoids, new firmware, etc. and certainly not just because the fluid has been changed. Phil |
