Home > Technical (L322) > How Do I Know If Active Damping Is Working ?
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I'm getting the impression that the ride on my L322 2012 4.4 TDV8 Westie is not as smooth and wafty as it used to be and there doesn't appear to be any difference in ride between normal and sport mode and I'm pretty sure there used to be.
I'm wondering if the active dampers are active all the time. I've heard that you should occasionally calibrate the ride, but I don't have the tools to be honest.
Is there anything I can do to confirm my suspicions, i.e. pop a breaker to disable active ride control to see if it is the case that the stiffer dampers are kicking in when they should be in wafting mode or if it's all in my mind.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684619 2nd Feb 2024 2:45pm
JayGee
Sport mode is just the gearbox program. Pull a connector off the top of a strut and the system will be disabled and go full hard 2012 TDV8 Vogue (L322)
Post #684623 2nd Feb 2024 3:27pm
AndyRoo
Hi JayGee, OK, I'll give that a go, so it defaults to hard, thanks
Post #684624 2nd Feb 2024 3:45pm
mjdronfield
As above…. Oh yes, it’s disabled then 🤣 made me feel sick and that was on a dual carriageway 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #684626 2nd Feb 2024 4:52pm
Baltic Blue
You also loose special programs function , from memory ?
Post #684630 2nd Feb 2024 5:20pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
If it's not working it'll feel like driving a series leafer suspension wise , wire snapped on mine a few years ago on top of A66 (you also get a warning on dash) 120 miles towing a tonne and half of caravan to Scotland and you know about it , make you feel sick and rattles your fillings out , set up caravan , remove top of strut and twist wires together , sorted till holiday over and can fix it properly at home .(had tools for MTB so torx bits with me )
Post #686543 26th Feb 2024 11:43pm
