![]() | Home > Technical (L322) > Drivers mirror juddering |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 84 ![]() ![]() ![]() |
A first and simple step would be to try spraying some silicon lubricant between the arm and mirror housing, and then opening and retracting the mirror a few times to spread it between the moving parts 2012 TDV8 Westminster in the New Forest
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 85 ![]() ![]() ![]() |
Following this thread in case someone posts disassembly instructions.
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
I'm thinking there are instructions on Wiki re this, IIRC |
You're absolutley right:
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 152 ![]() ![]() ![]() |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Be careful Old-un...... Those pictures do not apply to a 2010-2012 mirror. They are completely different! The older I get, the more I realise that people confuse wrinkles for wisdom |
OK RR owner |
