![]() | Home > Maintenance & Mods (L322) > Iid please help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35702 ![]() ![]() |
withe a iidtool you can revert to the settings before any adjustments....or leave for an hour and see. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3833 ![]() ![]() ![]() |
Yes you can Stan if it’s a 2011 4.4 tdV8 ?
my bad mike.. |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
Thanks, all cleared now but no digital speedo Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
how to from the wiki,
From memory it’s in the body control module BCM, something like activate 2nd speedo.
On holiday from work, new car, new iid tool, complete idiot, what can possibly go wrong 😂 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
The good thing about this forum, you can always rely on Pete |
Anytime you change something in the CCF it will throw a set of warnings and system failures. You just shut down, lock and unlock the car and it will be fine. You will also see the clock resets as do windows , date, etc which is anhoying. 2012 TDV8 Vogue (L322) |
Many thanks for that info Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Thanks Stan I did read and follow that. The last bit is not so clear, do you know what I have to select for the digital speedo? I selected second display units same as trip meter Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 232 ![]() ![]() ![]() |
Are you not supposed to just have the ignition on to edit the CCF? |
The GAP site has a very comprehensive FAQ in addition to the user manual where 99% of issues or questions can be resolved. Anything unusual that can't be found and emails to the team are usualy answered very quickly. 2012 TDV8 Vogue (L322) |
