Home > Maintenance & Mods (L322) > Costco engine oil (2009 facelift, 3.6 TDV8)
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
As is usual, I'll be servicing my new (to me) L322 twice a year and I'm looking around for accessible engine oils ie able to grab whenever as opposed to the cheapest.
On my aimless afternoon stroll in Costco today, I noticed a couple of strong contenders which, per my thorough research on here look rather worthy... both 5W30.
1 - this was the Castrol Magnatec which meets A5/B5 and Ford WSS-M2C913-C/D spec (ca. £35 for 5L)
2 - the most interesting one at 20L for ca. £70 was a Chevron branded "Supreme Motor Oil" which meets A5/B5 spec but doesn't denote any further spec. A bit of reading around infers this could also be compatible with my engine (see title).
My question is, has anyone had any experience with either of these and/or are any of them absolute no-gos? As mentioned, I'm looking for a solid oil to do me for 5k/6mths. I only ask a. for a bit of reassurance and b. some first hand experience as there are many conflicting recommendations online.
NB. I've also checked the L322 WSM per another thread (thanks Danb_220_201) which indicates these would be suitable.
Thanks all in advance!
R 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #689086 26th Mar 2024 8:42pm
garyRR
They don't sound like especially good deals.
5W-30
ACEA A5
API SL/SN
STJLR.03.5003
https://www.mannol.de/products/motor-oils-...a-fr-5w-30 (£37 for 10 litres, £60 for 20L from Carousel Car Parts)
https://www.smithandallan.com/product/smit...e-oil-4140 (£27 for 5 litres delivered, 20L for £72) 2015 Range Rover Autobiography 4.4 SDV8
Post #689094 26th Mar 2024 10:43pm
JayGee
Agree with Gary - nothing good about those prices. On a 3.6 you can't realy go wrong with an oil as long as it's the right viscosity grade as there is no DPF to worry about for. Just make sure you change it at intervals at least way shorter than the official service interval. 2012 TDV8 Vogue (L322)
Post #689101 27th Mar 2024 8:21am
rryan
Thank you both, really helpful inputs as always. I’ll get ordering Thumbs Up 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #689103 27th Mar 2024 9:15am
cass
The problem with using any lubricant other than that specified by LR is that you (or probably the next owner) wont know that it wasn't good enough until it is too late.
I often wonder how many of the problems like failed turbos that add to the story of "poor reliability" are actually down to someone saving £30 on an oil change?
Post #689113 27th Mar 2024 11:13am
garyRR
Not quite true.
Most oils carry 'Approvals' and 'Meets' specifications.
If you purchase an oil with the relevant manufacturer approval, it has been tested and approved to meet their standards.
'Meets' means the manufacturer says their oil does, but they haven't gained the necessary approval.
Smith and Allan base oils are Shell and they're well-trusted on the forum.
Frequent oil changes (I.e every 5,000-7,500 miles) are more important than the oil used being "genuine" or not. In practice most main dealers buy their oil from whoever sells them the correct spec at the cheapest price - so there's little (if anything) to gain, except paying 3-4x the price for it, making you reluctant to want to change it every 5,000 miles. 2015 Range Rover Autobiography 4.4 SDV8
Post #689123 27th Mar 2024 12:52pm
cass
I think we're probably in agreement, when I said specified I was thinking of the various specifications and not the brands. I don't know enough about the what the specs mean to be able to separate the important bits from the marketing Bull so I make sure that I get an exact match (usually Smith & Allan).
I've just seen too many examples of folks using the cheapest oil/filter available without any understanding of what modern oils need to do.
I've even seen a BMW diesel suffer brake failure due to the wrong engine oil being used - sounds unbelievable but it is a fact. Anyone care to guess how that happened?
Post #689210 28th Mar 2024 11:58am
rryan
These posts were definitely a good read and informative, cheers both. I was never intending to go with the cheapest parts but was looking for easily accessible, meaning I could grab replacements anytime as opposed to have to dig or wait for them.
S&A look like a great option, I've seen them pop up a few times now and having a 20L option is perfect as an annual purchase. I'm sold!
On the BWM, I'm perplexed as to how engine oil can affect the brakes?! Do tell... 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #689211 28th Mar 2024 12:11pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Vacuum pump failure due to oil deposits leading to a loss of assistance?
Cannot see how there could be a total failure hydraulically due to wrong engine oil, so would have to be an assistance failure, unless the braking system had been designed non-compliant with type approval legislation. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #689212 28th Mar 2024 12:37pm
cass
"Vacuum pump failure due to oil deposits leading to a loss of assistance?" Spot on, you're right the brakes didn't actually fail but they didn't do what the driver expected them to do when she put her foot on the pedal so the perception was that they had failed.
Long story short, after lots of threats and accusations from the driver, the car ended up in a BMW main dealer workshop. I saw the engine with the rocker cover off and it's no exaggeration to say that you could dig the black deposits out with a spoon. BMW Tech had seen similar but not as bad, he suspected it had been run on non synthetic oil. BMW reckoned it needed a new engine and refused to reassemble what they had taken off.
Post #689250 28th Mar 2024 6:07pm
JayGee
How long ago was that? Sounds like the 'sludge' issue that plagued cars in the 90's 2012 TDV8 Vogue (L322)
Post #689260 28th Mar 2024 7:33pm
cass
Yes, it even looked like said issue but it was a 14 plate car and it wasn't that old at the time so I'm guessing 2019 ish.
Post #689340 29th Mar 2024 5:24pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
When an oil blender states
Quote:
Momentum FSX 5W-30 is a high quality, fully synthetic passenger car motor oil, manufactured from high quality virgin base stocks and an advanced additive system offering excellent performance in both petrol and diesel engines.
then I would like to see the base oil listed in the SDS, with CAS number.
And it isn't.
Only the anti oxidant additive is listed, Bis-(nonylphenyl)amine, CAS 36878-20-3
The rest of the specs look ok and nowadays they can be easily reached by using Group III base stocks that are not truly synthetic.
The one and only way to show if an oil performs as good as you think it does is to have it analyzed, iow do a Used Oil Analysis (UOA), that will show, among others, viscosity after using it, fuel dilution, wear metals (always good for a nice debate) and leftover TBN. 2012 4.4TDV8
2000 Honda S2000
Post #690053 6th Apr 2024 9:37am
