![]() | Home > Technical (L405) > Restricted performance, Engine won't turn off... |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Probably way off base. but "running on" was a sign of timing being over advanced. Could it possibly be an intermittent error with the crank position sensor causing a timing shift?
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
Does your IIDtool's configuration show 2 types of faults set to show? I can't remember which one it is that isn't on ex factory but needs to be set on to show all faults. L405 D350 SE Carpathian Grey D5 19" rims |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Thanks for taking the time to post chaps....
| jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201
It is called "pending faults" and by default are not shown. |
Graeme and Jimmy,
You might want to check the PCM status to see if there is a later version that might have a bug fixed. L405 D350 SE Carpathian Grey D5 19" rims |
| Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 17
I had exactly your phenomenon. It was an EGT-sensor that started to act up. It was gradually deviating and randomly reading a temperature that was too much off compared to the others, which triggered a plausibility check.
Graeme, that's a good call, thanks for your thoughts, much appreciated...
For me it was Bank 1, Sensor 2. The easiest one to get to. A couple of threads about it:
Thanks a lot... |
| ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 55 |
Did you solve this Haylands? |
A friend who is a JLR master tech comes back with this
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I know this is an old thread (I used the search) but mine did something similar this morning. I stopped the car pressed the stop button, engine ran on but did stop after a second or two. When I restarted the fault was gone and the car behaved perfectly, although I have the BT iiDTool in the car I couldn't used it as my iPhone was at home.
Geoff, seems one of those problems that needs to get worse before you can find which sensor it is... mines been behaving since...
| All times are GMT |
