Home > Technical (L405) > Radar sensor blocked, IEB not available, but not really...
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I've had problems with this for years gradually getting worse and worse, usually in bad weather, so assumed it was build up of dirt, so finally removed the bumper to clean the radar sensor, but it was fine and made no difference.
It works for the first 2 miles or so after any restart, then throws a wobbly without fail.
Is this a common failure and do I just replace the sensor, or from others experience, is it likely to be something more involved??
Any advice much appreciated as ever!
Thanks
Neil.
2013 L405 SDV8 142k miles.
Post #694505 15th Jun 2024 7:09pm
I had this issue on mine back in 2021 when I bought the car. Supplying stealer first tried a s/w update, but that only worked for a couple of weeks and eventually they had to replace the radar unit. Been fine ever since. Its in this thread https://www.fullfatrr.com/forum/topic38805.html Mike - MPx
Post #694521 15th Jun 2024 11:21pm
comports
Morning Neil,
I have a similar issue however I think mine is being triggered by something (I could be wrong)
I can replay exactly one place where mine will all go mad. If I leave my house and head towards Chelmsford, via one particular road, and it doesn't matter if I'm heading out or heading home I get near to a antenna mast (probaby not called that) full of dishes and arials. Within the space of 10 yds I'd say it 'trips'.
Its not distance travelled related as I can take another road out to Chelmsford and have never had a problem. There are a few other spots I've found that also seem to have this affect.
It resets itself after 15 mins or so and radar/adaptive cruise all work fine. I've not tested the IEB system....cos I'm no where near brave enough!
Somene else posted that they could pinpoint a certain stretch of road or junction where they suffered the same but not sure if they ever found a solution.
Regards, Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #694525 16th Jun 2024 8:32am
Mine does it occasionally in heavy rain, but seems to clear itself again reasonably quickly.
Post #694526 16th Jun 2024 9:22am
Kot
Re: Radar sensor blocked, IEB not available, but not really.
Do you have a code scanner? What DTC errors do you have when it throws a wobble? 2018 SE SDV8 4.4 Byron Blue
Post #694527 16th Jun 2024 9:22am
Neil183
I couldn't read a code as once the ignition was off the fault cleared...
So, I took a punt, bought a used radar sensor, swapped it out and heh presto, I'm pleased to say that it is all back working perfectly, so happy!
Thanks for all the help.
Best
Neil.
Post #695269 29th Jun 2024 6:06pm
