Home > Technical (L322) > Front suspension raises while driving.
kevinp
This has been happening for a long time now. After driving the car and switching the engine off, after about 15 seconds the front suspension will drop between 1 and 2 inches but it drops and stops at the recommended height of 493mm which means it is riding too high while driving.
I have fitted new front strut assemblies, because of a burst air bag, but it did it before this as well.
I can hear some air releasing under the right wheel arch when it does it but I presume this is the valve block letting air out the bags.
When connected to the IID tool the voltage traces move when I slightly move the height sensors.
All the front suspension components have been replaced.
So, can anyone come up with any suggestions as to why it is doing this?
Thanks Kev.
[ 2011 4.4 TDV8 ]
Post #695286 30th Jun 2024 10:37am
JayGee
I assume you have recently done a calibration? Mine would readjust sometimes but since I replaced a height sensor that failed I haven't noticed it happening. When I took the sensor off the pivot was very stiff so I assumed it was suddenly jerking and sending a new height reading to the ECU rather than continualy adjusting. 2012 TDV8 Vogue (L322)
Post #695291 30th Jun 2024 1:31pm
kevinp
Yes, recent calibration and all the sensor points are free to move.
Just don't understand what's happening.
How can the bags be pumping up while driving.
I can only think there is something wrong with the sensors.
I think I'll uncouple the sensors and move them slowly to see if there are any voltage spikes.
What brand sensor did you use as I hear pattern ones arn't reliable?
Post #695299 30th Jun 2024 4:22pm
JayGee
Used OE for the one I replaced but bought pattern part front and rear to keep as spares in the boot incase another failed as learnt a valuable lesson that if a sensor fails it can leave you stranded. 2012 TDV8 Vogue (L322)
Post #695300 30th Jun 2024 4:39pm
