![]() | Home > Technical (L322) > oh no! idle squeal on V8 RR 2004 - only just bought it :( |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
fanbelt? "RANGEISM WILL NOT BE TOLERATED"
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
sounds like alternator noise.. |
| RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380
i dont think it could be the alternator as when i sprayed wd40 the noise went away, if the noise stayed i might have thought it was but then again i dont have much technical knowledge about this. but im learning
if you sprayed the wd40 onto the alternator pulley assembly then maybe .
Ill get under the hood tomorrow and see if i can have a better look, its just so dam tight that you can barley see or reach lower down.... cheers again, ill let you know tomorrow what i find... any other tips for when i do have a look ? |
a torch will help and spray little by little.. |
take a cup of tea outside with you.....always nice to have a tea when working on your car......oh and its bonnet "RANGEISM WILL NOT BE TOLERATED"
I got the kettle on timer already for tomorrow thats what happens when you watch too much american tv. haha |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
I have had this on a few I think its the fanbelt pulley. Goes away with 3-1 spray or WD40 but only on a temporary basis.... |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
I've had this for weeks also had it about two year ago it was the fanbelt pulley that had to be replaced so now I don't bother with it I just turn the tranny up and mine is only sitting at 55k miles plus my brother might be buying it for £12k so he can get it sorted if he buys it |
I'm not fussed about the squeal tbh I can use 3 in 1 spray or even I heard some chalk used on violins works perfect. I'm just thinking if it is the pulleys would it be best to get the culprit fixed or is it possible for it to ever break? Or does it essentially just get noisier and noisier. Lollllll make sure u give it a squirt of wd40 before you sell it to him. "as good as new" I'm going to ask a dumb question: what do you mean turn the tranny up Cheers guys. |
tranny = transistor radio |
Ahhhhhhhhh hmmmm feel silly now Good job I've got harman karden then |
