![]() | Home > Technical (L322) > Oil leak on top of block |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 233 ![]() ![]() ![]() |
Hi Marcus,
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Inlet/rocker cover leak? Well known problem and a right pain to do unfortunately |
I feared it is going to be a pain to do, access is limited and by the look of things you have to unclip a mass of electrical connectors and a whole heap of other bits. I am going to remove the inlet plemum first and see if I can get a bit more visibility. My thinking is that it could be one of the oil feeds to the turbos, the leak doesn't show when running stationary but is definately there when you increase the revs.
Well, it seems some homeless rodent has taken up residence in the L/H side of the engine, quite how I'm going to get all the straw and stuff out I don't know yet, tried using a couple of bits of bamboo as chopsticks but my technique needs refining. The next plan is to remove as much of the oil as possible, a magical spell would be helpful, and then lay my self down on the engine whilst the OH applies the trottle as commanded and see if I can see the oil appearing. |
