Home > Technical (L322) > folding wing mirrors
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
my wing mirrors fold in when i press the little button but unfortunately they come straight back out again which is rather annoying. Someone told me to have a look at the limit switches so i dismantled the mirror to find that there arent any, just a couple of worm gears and a little servo motor. Am i correct that this would suggest a fault with the controller? Is this a module that can be replaced?
Post #77622 25th Aug 2011 9:28pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
could be the faulty microswitch problem, common fault.
Post #77645 25th Aug 2011 11:02pm
there is this in our wiki that might help
http://www.fullfatrr.com/wiki/Folding_Mirrors
Post #77828 27th Aug 2011 5:43pm
oodathort
some engineer
Post #77856 27th Aug 2011 7:30pm
So the microswitch actually on the mirror housing somewhere? Where? or on the door switch panel? Photos will help? .
Post #77868 27th Aug 2011 9:40pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
What if the mirrors dont work at all. Mine have never folded in since I bought the car a few months ago. I have read a number of posts about sync problems etc. but nothing about the mirrors not working at all. Any ideas anyone? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #77870 27th Aug 2011 9:54pm
oodathort
First remove the mirror cover using a small but wide blade screwdriver to ping the cover off, then by the hinge part you will see a plastic cover over the micro switch the cover slides off towards you, the common problem is that the steel arm on the micro switch gets bent and does not make when in home postion if you re shape it and before putting cover back on try the operation, if its wrong the mirror will close in then return out imidiatley just play with the arm until you get it right
Post #77893 28th Aug 2011 7:13am
Another pictorial howto on dismantling and accessing the microswitches for wing mirrors ('02 - '05) early type mirrors
http://www.fullfatrr.com/gallery/thumbnails.php?album=341
(and Scarey, yes you can Wink) .
Post #82199 18th Sep 2011 3:30pm
done joe.. Thumbs Up ... - .- -.
Post #82204 18th Sep 2011 3:49pm
