![]() | Home > Technical (L322) > L322 Td6 GM 5L40E Gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1036 ![]() ![]() |
According to this Sonnax document, the 802 plate code is correct for the L322. The 5L40-E that I tore down (https://xoutpost.com/bmw-sav-forums/x5-e53...rdown.html) had a 376 plate (also on Sonnax’s list for the L322). However, there’s no mention of a 347 plate.
hgbosch Member Since: 27 Mar 2015 Location: Pretoria Posts: 19 ![]() ![]() |
Hi Phil
Do you have access to any diagnostic kit which can measure and record live data? I guess the first thing you need to establish is whether the TC LUC solenoid is being wrongly triggered by the transmission controller, or if the LUC engagement/disengagement is caused by a hydro-mechanical issue with the valve body assembly.
Hi Phil
Hi Phil
