Home > Technical (L322) > 4.4TDV8 leak from fuel filter .... AGAIN !!
Benji1
Australia
Hi Crusty,
Been in your spot before.
Through trial and error I found that the screw in LR water drain and sensor connector plug in your picture leaks from the sensor fitting in its centre. You will find if you play around with it that there is just a little "slop" allowing the sensor to move away from the hard plastic washers that are supposed to seal it.
Under pressure, diesel can pour out through the gap.
I changed mine out for the 5 cent plastic fitting supplied with the fuel filter and zipper clipped the water in fuel sensor to the base of the filter.
I still get the water in fuel code coming up every now and then however I was getting this anyway with the leaking original LR fitting. id rather put up with this every day than have to clean up leaking diesel all over the place.
I have enquired about a replacement fitting however its not sold separately by LR. You have to buy an entire new filter housing to get the fitting.
Post #707478 23rd Dec 2024 10:44am
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Chaps,
I would suggest then that there exists more than one potential source for possible leaks from the knurled basin fitting. Mine appears to leak not from the water sensor connection but from the drain outlet. See my thread posted in August :
https://www.fullfatrr.com/forum/topic71055.html
Initially this was caused by the failure of the viton washer which had clearly sustained significant perishing giving rise to a fuel leak amounting to a near torrent. Subsequent trials of replacement washers, genuine and otherwise, have provided a measure of relief, but sadly not amounting to a complete resolution.
Crusty - With this in mind, I look forward to reading your summary of the outcome following fitting of replacement parts as per your discussion with Mr. Tee.
Good luck.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #707486 23rd Dec 2024 11:41am
Crusty21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I have now finally .... fingers crossed .... resolved the problem Very Happy ..... and actually killed 2 birds with one stone
What I didn't mention was the amber "Restricted Performance" message I was getting for the past year (before any signs of a diesel leak) and an occasional "Water in fuel" warning after signs of a leak.
As there was no actual restriction of performance I just delayed the fix.
I had figured that these warnings were related to a faulty loom / screw in basin at base of filter
So it was always my intention to swap out the wiring loom and basin fitting but as you know they are not sold separately any more from the entire fuel filter housing. I read on this forum that the loom is the same on the 3.6 TDV8 so my plan was to buy a SH housing from the 3.6 and transplant the loom to the 4.4 housing.
however I also read that the loom from a Transit van filter housing is exactly the same as on the 3.6 & 4.4. I then discovered I could buy the whole housing brand new (which incidentally also includes a filter !!) for under £30.
So that's what I did
It took about 30 mins to remove the fuel filter housing on the 4.4 TDV8, swap over the loom and basin / sensor and refit to the RR .... it's an easy job.
On inspection with the housing removed the leak appeared to be coming from the base of sensor screw on the aluminium cap and not the outlet. I reckon if diesel is leaking from the outlet then it's likely a washer issue
The replacement knurled basin fitting is plastic rather than aluminium but still works great
To date ..... leak fixed, Restricted Performance warning gone , Water in fuel warning gone
Probably saved myself circa £500+
Part number for Ford Part - 6C119155BE 1685716 .... as shown in photo
Hope this helps ..... this forum is a gold mine of info ... it's certainly helped me and my wallet Thumbs Up
 2011 TDV8 4.4 Vogue SE
Post #707508 23rd Dec 2024 4:20pm
Well done matey. And thank you.
Have just now clicked buy-it-now for one of these.
Together with a selection of washers from various sources as well as a genuine LR fuel filter, I am really hoping that I now have the means to put this to bed once and for all.
Thanks again.
Have a good Christmas.
Post #707516 23rd Dec 2024 5:03pm
Crusty21
Good luck with it Warwick ..... I'm confident you will sort it Thumbs Up
If you need any more info give me a shout on this thread anytime 2011 TDV8 4.4 Vogue SE
Post #707521 23rd Dec 2024 5:31pm
Joff1961
Have been having same issue on my 2012 Winchester, just had the £30 part in the post, also have a Land Rover part LR072685s which is £149.99 from a well known off road parts company which if the £30 part works the other part will be going back.
Post #719307 6th Jun 2025 1:18pm
Although I did acquire a (Ford) fuel filter housing/assembly, I didn't get around to using this. With nothing visibly amiss with the existing kit, I felt disinclined to replace it except as a last resort.
With the fuel filter being an unbranded item of uncertain providence I opted instead to seek a replacement.
Unable at the time to locate a Mahle item, I ended up with genuine LR, surprisingly for about the same money.
Visual inspection of the old filter revealed nothing apparently awry. Similarly, giving it a shake.
But thus far at least, this does appear to have resolved the issue. Presumably then something must have broken down inside the filter.
Which must have been the case pretty much from when acquired the car back in 2018. Because I think the corresponding diesel stain on my driveway had been present from around that time or not long after.
Should it fail again then it may be time to start thinking about fuel pressure to the filter.
But for now, cautious optimism......
Post #719310 6th Jun 2025 2:16pm
Crusty21
The Ford filter housing is not a replacement for the JLR housing, nor is the filter that comes with it.
The wiring for the sensor can be removed from the Ford part and replace the OEM.
If the OEM wiring is faulty - as it was with mine - it threw a Restricted Performance warning and 'Water in fuel'.
I simply removed the faulty sensor and replaced it with the Ford one ..... all warnings gone immediately Very Happy Very Happy
then just binned what remained of the Ford filter housing
£30 v £150 ? ..... well worth it Laughing
Interestingly, the replacement sensor was not available from JLR at the time .... you were "encouraged " to buy the whole filter housing Censored
I'm sure you'll be sending that JLR part back Joff 1961 Very Happy ..... just beware the of the "returns window" ... its very short !!! 2011 TDV8 4.4 Vogue SE
Post #719312 6th Jun 2025 2:44pm
Yes, quite right. Having not looked at this for a while and with my focus having shifted to the fuel filter, I'd forgotten the detail.
As for the returns window, I fear that has long since closed.
Post #719316 6th Jun 2025 3:41pm
Benji1
Australia
From my experience your leak is coming from the sensor.
In my case, there was a little "play" between the sensor and the screw in fitting that fits to the bottom of the filter.
This play allowed diesel to pass through the gap created.
Tiny nylon washers are the likely fault however as it appears to be a fully sealed unit I've not attempted a repair on it. Its a really poor design.
My solution has been to install the plastic non sensor plug that comes with the filter and put up with the random restricted performance (water in fuel sensor) message that comes up from time to time however annoying this is.
Post #719575 11th Jun 2025 7:57am
