Home > Technical (L322) > Fault codes dissappear when engine warm
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
Hi. Just wondering if anyone has had this issues where fault code are they when car engine is cold but when it starts to get upto temperature they dissappear.
Hi. Just wondering if anyone has had the same issue where they have fault codes stored and appear when starting the car cold but left to get upto temperature the codes dissappear?
Post #708915 12th Jan 2025 10:47am
JayGee
It’s entirely possible a sensor could come back into life / spec when warmed up. 2012 TDV8 Vogue (L322)
Post #708919 12th Jan 2025 11:18am
Apps
Yes it's just annoying. I think I will replace the map sensors and see if that helps the issue out
Post #708920 12th Jan 2025 11:30am
JayGee
Is yours a 4.4 or 3.6? If the former there is only one MAP sensor on the top of the 'donut' shaped intake under the engine cover. Worth removing in and cleaning out the soot which rapidly builds up and checking the wiring / connector for electical continuity. 2012 TDV8 Vogue (L322)
Post #708921 12th Jan 2025 11:43am
Apps
Mine a 2010 3.6. So I think there is 2 on the top of the engine
Post #708923 12th Jan 2025 12:05pm
JayGee
Even easier then - swop them around and see if the fault follows to bank A 2012 TDV8 Vogue (L322)
Post #708927 12th Jan 2025 12:53pm
Apps
Yes good idea. When I get home and try and let you know. What ramge rover do you have?
Post #708932 12th Jan 2025 1:31pm
Hover your cursor over the little picture of a Rangie under the persons name in the left side box. It will show you what car they have, if they have filled in their profile... Pete
Post #708954 12th Jan 2025 6:31pm
