![]() | Home > General > To service or not to service? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3898 ![]() ![]() ![]() |
Dirty hands - not for me |
Supershuttle, if you don't use it i can take the whole lot off for you and put standard bits back on yours |
Sorry mate, thanks for the offer, but I do use it. I would just like the two bits not to be seized together, because it's just wrong ![]() ![]() |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
Have you tried putting some heat on it? That usually frees up most seized bits. |
Why not put a big heavy unit on the back of it while suspension in access mode, then just lift up the jockey wheel a tiny bit, unlock the joint, then raise the suspension to normal heightand tap it with the hammer being careful to avoid backlash... should come out a treat as long as the nose weight isn't massively high but not far off the limit... |
The only heat I have available if the wife's hairdryer ![]() |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
christ you'll be there for ages |
Have you seen her hairdryer
How long had it been stuck in place - I reckon this one has been on for 4 years or more the bag and the rubber bung, fortunately still in the boot, look brand new. That's why I was going to ask the indy to remove it on the first service. Geoff |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
My guess is that mine was fitted to the vehicle when new and never removed. The locking pin was seized solid and had to be removed in bits, then I spent months spraying loads of releasing fluids and forcing it with a jack at the back of the plate to no avail. The mechanic who did eventually part it could not believe it was such a stubborn item to split |
Cool,
Is it possible to remove Towbar without the key as although I received one key I have lost it now I look like a farmer all year round. Present :2008 TDV8 HSE
If it's not as big as the one in Mick's picture then get down to B&Q and get one of those little plumbing blow lamps. They may look weedy but 5 minutes of heat with one of them and a hefty whack with a hammer and it should come out. |
I doubt if a plumbers gas torch from B&Q will work, there is not enough heat from it to sufficiently heat the surrounding metal. The temperatures below are a rough indication of what each type of gas torch output is. Butane..............1430°C = 2600°F Propane.............1995°C = 3623°F Mapp Gas..........3160°C = 5720°F (this is what I use) Oxyacetylene.....3316°C = 6000°F |
