![]() | Home > Technical (L322) > ZF8 oil and filter change |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Did you have the engine ticking over while you checked the fluid level?
rainifa Member Since: 23 Nov 2012 Location: Plymouth Posts: 22 ![]() ![]() |
Hi Phil. No, I turned it off after I’d got it up to temp and then removed the fill plug. I got another half litre in at that point, but total less than 3 litres. Do you think that would make much difference, i.e. another litre? Thanks |
I think you’re right Phil. I’ve re-read the instructions and missed the bit where it says keep the engine running! Thanks for your suggestion-spot on. |
The reason it’s important is because, the moment you turn the engine off, the transmission oil pump stops and the torque converter starts to drain down into the sump. This produces an artificially high fluid level, preventing you from putting in the correct amount of fluid before it overflows from the filler hole.
Yep, makes complete sense. Loads more jobs to do so I’m sure I’ll be back😂 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Full Fat 4x4 has just done a YouTube video on this
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Is this the same gearbox in a 2013 4.4 405? 405 AB exec seats Baltic and Cirrus
Yep - ZF 8HP70
