![]() | Home > Technical (L322) > Well it happened, top coolant hose |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
Indeed. Seem to think it was around £90 when mine broke a few years ago, maybe 4 or 5 years…..
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 936 ![]() ![]() |
See here - easy & cheap fix |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
Thanks guys, but unfortunately I won't be able to do a temporary fix as I have to take my daughter back to Lichfield tomorrow so not got the time for the repair. Shame it didn't happen early this morning otherwise I'd had plenty of time to sort. Oh well, see if I can use the works van and just order the part There's a land rover parts shop in tredegar called foundry 4X4 which I didn't know about until today. But the repair is good to know should it happen again in the future. |
Foundry have been going for years. Sure I’ve ordered from them at least once.
How easy is it to get to the bottom hose and remove it? Looks like it's a bit of tight fit under the throttle body. Would it just be worth replacing the centre piece as it looks a lot easier to do rather than replace the whole hose? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
The fitting at the engine end is easy enough to remove by lifting the retaining clip, but first remove the air intake hose. |
All fixed, bought the part from foundry 4X4 in tredegar for £55. 20 minutes to fit and bleed and now all good. Thanks guys.
