Home > Maintenance & Mods (L322) > RPM fluctuations while driving
Buie
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
I have a 2012 5.0 HSE and I've cleaned the MAF sensors, done a coolant, transmission and oil change, and I still have an issue where the engine ( after idle and under load or cruising) will predictably surge about 100 rpm. Has anyone else experienced this?
I've scanned it and the only codes that I think may play into this are B11DB-87 battery monitor and B12C9-88 LIN Bus
While it's very slight and the the vehicle is 100% drivable but as a "new to me" vehicle I want to sort out everything that I can so I can just enjoy it.
Any tips of troubleshooting ideas would be appreciated.
Post #713299 4th Mar 2025 4:26pm
Gsxr1250dave
Yes there is a thread going on at the moment on this very issue
https://www.fullfatrr.com/forum/topic72665.html
Post #713314 4th Mar 2025 7:13pm
Buie
Thank you for the quick reply. However, my issue was just a slight bit different. My transmission is very smooth and functioning correctly. It's the actual speed of the engine that varies in that slight amount. Initially, I thought it might have something to do with the MAF sensor or air filter, restricting the amount of fuel air mix.
I'm trying my best not to take it to the main dealer, but I feel like I need to bite the bullet and just let them do a full diagnosis and maybe then I can get a list of items that I can begin to service myself versus pay the shop to knock out.
Post #713331 4th Mar 2025 11:52pm
RRPhil
The torque converter lock-up clutch misbehaving in its controlled slip mode produces exactly that effect.
Phil
Post #713332 5th Mar 2025 12:58am
Buie
Thanks Phil. Looks like I'll take a run a the solenoids first and pray that sorts out the issue.
Post #713333 5th Mar 2025 1:03am
dhallworth
This is 100% what my car was doing when RRPhil helped me diagnose it. I've done around 6000 miles in it since replacing the solenoids and servicing the gearbox and she's been perfect since! Thumbs Up
Other than not locking up properly the gearbox on my car felt like it was perfect too. I did oxygen sensors, MAF and MAP sensors, checked for vacuum leaks, etc. etc. before realising it was the gearbox.
Post #713334 5th Mar 2025 1:13am
Rambles
Out of curiosity
What would a ZF service centre / Indy charge for a complete change of solenoids in the ZF8 gearbox ?
Post #713352 5th Mar 2025 10:18am
Gsxr1250dave
I think you need to ask that of a zf gearbox centre
Post #713358 5th Mar 2025 11:50am
