![]() | Home > General > L322 5.0 supercharged anyone had one? |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057
This forum is full of info try the search function |
| MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 643
Had a 2012 5.0 SC. Awesome car. I did circa 50k miles in it over more than 4 years and generally reliable. Gave me some jip with the aircon not working - most of the components replaced in the end - high cost. But in the end (at about 108k miles) the chains went at an awkward time for me so instead of repair I replaced it. The repair route is eye watering expensive for the chains and will have the car off the road for quite a while even assuming you can find someone to do it. So either make sure its been done or reserve a few thou for when it happens to you. (From 2013 on there was a modification so those engines dont suffer the same ... and the replacement guides are the later ones). GLWTS Mike - MPx
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 107
Thank you mpx
Went to see one today 10 plate with 79k miles 5.0 autobiography up for 15k
| AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 72
“ Cold start sounds rough for like 20 seconds then settles no metalic noises”
Thanks
Went to see this after winning at auction amazing spec
